2000 Cirrus 2.5L will not start, no spark after replacing timing belt
Old Aug 11, 2014 | 04:10 PM
lost-in-space's Avatar
Angry 2000 Cirrus 2.5L will not start, no spark after replacing timing belt
I have a 2000 Cirrus 2.5L that needed a water pump, I tore it down and made sure of the timing mark alignments before taking the belt off. Before bolting it all back together after putting the new water pump and timing belt on I rotated the engine a couple of times and checked the timing marks again and they were right on.
I also replaced the spark plug and plug wires, I had to remove the distributor cap to replace the wires, finished putting everything back together and went to start it and it turns over but will not start. I pulled one of the plug wires and put another plug in the wire and grounded it but I do not see any spark. The distributor and cap were replaced about 2 months ago.
I am at a lose and need some direction where to go next. What things to look at?
In the Chilton's and on a couple of other websites at the very end of the directions it indicated that you need to use a scan tool to "Relearn the Crankshaft and Camshaft alignment" after replacing a timing belt. Is this true and if so, will it keep the car from starting.
Old Aug 11, 2014 | 09:33 PM
Im gonna say u messed up something with the cap in that area
Old Aug 12, 2014 | 05:30 PM
That was the trick! 1 of the 2 plugs on the distributor came unplugged. Runs like a champ. Thanks!!!
Old Dec 5, 2014 | 10:36 PM
cirrus98's Avatar
Quick question for you. I'm doing my Timing belt/water pump on my Cirrus but i cannot remove the rear cover on the belt. I took off the bolts at the back of the block(2 of them) plus everything on the side. Is there anything else i'm missing. My engine as been sitting on the jack all week long.
Justdel
Jun 25, 2013 11:20 AM
p8ntballnxj
Feb 5, 2012 07:23 PM
powerman300m
13
Dec 7, 2011 08:57 PM
shaka38
Sep 12, 2011 10:29 AM
sebringphanatic
Mar 22, 2008 07:57 AM
