Could This Be The Cause Of My PCM's Going Bad
Old 05-13-2010, 03:10 PM
BIGCJ's Avatar
Default Could This Be The Cause Of My PCM's Going Bad
I was testing some of the wires on my Chrysler Cirrus and i found something weird and i don't know if it should be like that. but when i tested my ground wire blue and black. i got a positive and a negative reading on the same wire.
I also tested this with test light.
I'm just wondering if it should be like this or not
Old 05-13-2010, 09:41 PM
need a whole lot more info then this all u gave was some info that no one in the right mind would even know what u are talking about.
year make and model what connector on the pcm what is wrong with the car to start with and a test light cant test for power and ground at the same time.
Old 05-14-2010, 04:23 AM
BIGCJ's Avatar
Its an 1996 Chrysler Cirrus LX 2.5L V6. The car will not start and the PCM is the problem this the second PCM put into the car.
was testing Sensor Ground K4 Black/Light blue. I test this for ground and positive at different times.
Old 05-14-2010, 06:19 AM
with the key on do u have sensor ground?
Old 05-16-2010, 08:23 AM
BIGCJ's Avatar
Yeah its getting ground
Old 05-16-2010, 08:38 AM
and when u turn the key off the ground goes away? if yes its not a sensor ground issue then
Old 05-16-2010, 09:24 AM
BIGCJ's Avatar
No i still have ground when the its turned off.
Old 05-16-2010, 10:11 PM
unplug the pcm see if the ground is still there
Old 05-17-2010, 03:53 AM
BIGCJ's Avatar
Yeah it's still getting ground when the PCM is unplugged.
Old 05-17-2010, 09:21 AM
u have a short to ground then on that circuit trace it down
Quick Reply: Could This Be The Cause Of My PCM's Going Bad
