Rear Wheel Bearing Replacement
Is the wheel bearing hub pressed on? I know I need to remove the tire, the brake drum and pry off the dust cap. Then there is a nut that needs to be removed. After that does the hub just pull off or do I need to use some sort of gear puller?
Thanks for your help!!
lastxit
Aug 22, 2016 09:47 PM
Daniel Craig
Apr 2, 2015 08:07 PM
travelmad
Aug 28, 2013 04:36 PM
