07 chrysler sebring key remote issue
Old Mar 23, 2011 | 12:25 PM
rustyman1's Avatar
Default 07 chrysler sebring key remote issue
The dash says "no fuse" and the key remote doesn't work anymore. Also has a red dot on the dash sometime. I checked all fuses I heard it could be some module that went bad just want a lil direction on what should be my next move. Any help is greatly appreciated.
Old Mar 23, 2011 | 01:14 PM
Djinn-n-Tonic's Avatar
There are two fuses (Green 30A) in a white plastic holder in the underhood fuse box. Pop the cap loose and check those two....
Old Mar 23, 2011 | 02:03 PM
rustyman1's Avatar
I did that.they were both fine.
Old Mar 23, 2011 | 03:14 PM
ok.....
A nO FuSE message indicates that IOD voltage has been lost. That white plastic holder contains The fuses to control IOD functions...
"IOD" Class is about to begin....
Radio, computer, interior lamps and various modules all use asmall amount of battery power, even when the car is turned off. During shipping and storage, that battery power is disconnected by lifting the "Ignition off Draw" connector in the fuse box, to prevent the imminent discharge of the battery over time.
Go thru the car and tell us what else does not work....
Old Mar 23, 2011 | 03:49 PM
rustyman1's Avatar
The blinkers won't stay on unless the car is running. from the inside the car doors won't open with the door switches unless the key is in the ignition in the run position or start position.
Old Mar 23, 2011 | 04:03 PM
Radio...???Dome lamps???......Compass??
Old Mar 23, 2011 | 04:14 PM
rustyman1's Avatar
All that still works fine though the radio won't shut off right away after taking out the key it takes like 10 sec. Unless I open the door or turn radio off manually
Old Mar 23, 2011 | 04:43 PM
Ok.....
You have an open splice somewhere in the dash harness, where the IOD line Branches off....
It is fixable, But You may want to consider professional help at this point.
Old Mar 23, 2011 | 04:46 PM
rustyman1's Avatar
Damn. That's what I was thinking I hate going in those harnesses.
NisCAPE
Jan 4, 2011 01:55 PM
AgEnT
May 13, 2008 08:22 AM
AgEnT
Dec 17, 2006 08:34 PM
prodrive98
Oct 27, 2006 11:23 PM
prodrive98
Oct 19, 2006 12:56 PM
