07 pacifica start up and transmission
Old Feb 20, 2009 | 09:44 PM
torred daytona1230's Avatar
Default 07 pacifica start up and transmission
I won an 07 Pacifica with the 4.0 engine. When I start the engine the car rumbles on start. Its not smooth at all. Also when driving the car the shifts are slow and clunky. Sometimes it feels like the cars stalls a little when it shifts.
The engine on start up feels like it jumps around. Its kind of hard to explain, but the dealer said it needs new Engine mounts. Mileage is under 30000. I have heard that the transmissions and torque converters on these cars suck.
Old Feb 21, 2009 | 02:20 AM
irdaneel's Avatar
It sounds like you have a vacuum problem somewhere. If not a gasket or hose, perhaps an EGR valve or PCV valve is faulty.
The mounts could possibly be just loose, but if the motor jumps around more than an inch or so, you should find and fix it.
Old Feb 23, 2009 | 01:28 AM
irdaneel's Avatar
Also, check your fluid levels if you haven't. Be sure to add the correct fluid. Chrysler trannys are particular about that.
Question? At 30,000 miles, wouldn't you still have a warranty even though you won it? You may want to contact Chrysler directly.
stu75stu
Aug 14, 2022 01:23 AM
jbda
Cirrus & Breeze
Apr 1, 2013 11:09 AM
maccus
Oct 26, 2012 02:29 AM
bate1
Jan 3, 2012 08:46 AM
farmerbob02
Apr 13, 2011 12:04 AM
