07 Sebring Limp Mode
Old Jan 19, 2013 | 01:05 PM
xarget's Avatar
Default 07 Sebring Limp Mode
Hello guys, I got a 2007 Chrysler Sebring, had a new transmission(41TE) put in and is still in limp mode, code P0700 and P0765, all sensors and solenoids are new, took to a dealer to have reprogramed but it wouldnt work and there computer was saying trans temp was -3 degrees F even though it was warm...the range sensor was damaged putting it in but the prongs are still good, could the range sensor being broken cause this or is it more likely the pcm? after the dealer messed with it for a while now all the lights on the gear indicator on the dash are on not just the gear it is in......thanks for any help or suggestions you can give me.....
Old May 6, 2013 | 05:39 PM
Fixit Jody's Avatar
Default 07 Sebring in limp mode
Hi, I'm going through the same cycle of replacing parts.
How did you finally fix the problem?
Old May 7, 2013 | 08:11 AM
xarget's Avatar
Default Pcm
Ended up replacing the PCM, and having it reflashed, bought a used one for $50.00
Heather
Sep 13, 2011 09:09 AM
studentmechanic
Aug 26, 2009 10:05 PM
flhtci
Aug 30, 2008 10:26 AM
nanu73bear
Sep 24, 2007 12:31 PM
luellajean
Aug 8, 2007 07:29 PM
