2005 pacifica starter problem need heeelllppp
Old Mar 1, 2009 | 05:00 PM
cantionebrown's Avatar
Default 2005 pacifica starter problem need heeelllppp
36000 miles 2nd starter bendix not engaging, starter turns, lights everything works when it snows or very cold weather something frezzes up starter stops working like i said starter turns bendix not comming out
Old Mar 2, 2009 | 08:40 PM
I used to have that problem with my 1967 MGB. You could get it going if you stuck your finger in the starter gear and wiggled it. Probably not practical on a Pacifica, though. It could be a lube problem with the Bendix, but first I would suspect a weak battery. If it works with a jump from a good battery, then I would definitely think about replacing the battery. If not, then I would check all the electrical connections leading to the starter for looseness or corrosion.
Old Mar 7, 2009 | 05:13 PM
Default starter problem
Is the starter bendix operated by a seperate wire? I ask because the starter turns
Old Mar 7, 2009 | 09:53 PM
The Bendix engages mechanically when the starter is energized. If the starter spins without being engaged, then it's a problem with the Bendix sticking, probably due to lack of lubrication. Was the car driven through any deep water? That could cause a problem like that. Was there a warranty on that replacement starter? If so, take it back. If not, go elsewhere.
Kendegreat
Feb 2, 2021 11:30 AM
rodger
Mar 22, 2011 07:00 AM
mrabutton
Jan 5, 2011 07:04 AM
cantionebrown
Mar 3, 2009 11:07 PM
cantionebrown
Mar 1, 2009 07:11 PM
