2006 300 3.5L RWD touring starter removal
Old Jul 30, 2015 | 09:40 AM
Sonny Wallace's Avatar
Default 2006 300 3.5L RWD touring starter removal
Does anyone know how to remove the starter from a 2006 Chrysler 300 RWD 3.5L touring model?
I have tried to remove the lower steering shaft but can not get it apart after removing the bolt in the center between the upper and lower steering shafts.
I have also removed the bolt at the bottom of the lower steering shaft and tried to move the entire shaft out of the way but the universals at the bottom are too big to get out of the way.
It appears that if I could get the upper and lower steering shaft to separate I have a chance to get the starter out. Without this there is no way I see to replace this starter.
Any help is greatly appreciated.
Thanks,
Sonny
Old Sep 10, 2015 | 12:36 AM
Naustic's Avatar
08 - Electrical/8F - Engine Systems/Starting/STARTER/Removal
3.5L
Labor Operations: Click to display a list of Labor Operations associated with this procedure
NOTE: All Wheel Drive procedure shown. Rear Wheel Drive Similar.
1. Disconnect and isolate negative battery cable at battery.
2. Remove the left side catalytic converter (4), (Refer to 11 - Exhaust System/CONVERTER, Catalytic - Removal) .
3. Remove battery cable nut (5) and battery cable (4) from solenoid stud (2).
4. Disconnect electrical connector (3) from starter solenoid terminal (1).
5. Remove starter mounting bolts (3), the electrical harness mounting bracket (4) should remain in position.
6. Rotate and remove starter assembly (1) from transmission.
7. Remove starter motor dust shield (2).
Sorry...no images or diagrams. Hope this helps though.
Old Mar 21, 2020 | 09:32 AM
Firah Bam's Avatar
Default parts no
may i know the parts no for the starter.. thank you
Old Mar 29, 2020 | 09:05 AM
You don't need a part number to order the part. Year, engine size, make and model is enough.
Tony77
Apr 3, 2020 12:54 PM
Sonny Wallace
Aug 10, 2015 11:56 AM
Sonny Wallace
Jul 22, 2015 09:10 AM
Sonny Wallace
Jul 21, 2015 09:26 AM
InfoSeek
Dec 25, 2010 12:09 AM
