2007 Sebring drivers door won't open
Old Feb 10, 2015 | 02:14 AM
nut430's Avatar
Default 2007 Sebring drivers door won't open
hi
Drivers door won't open I have tried disconnect and reconnect battery with no luck. Any ideas
Thanks in advance
Old Feb 10, 2015 | 03:40 PM
ChryslerCACares's Avatar
Originally Posted by nut430
hi
Thanks in advance
nut430,
What exactly are you experiencing, a locked door that won't release?
Please provide more details.
Old Feb 11, 2015 | 02:11 AM
nut430's Avatar
All doors unlock and open other than drivers door. Tried disconnecting battery and reconnecting but still won't open. Today I wiggled the wiring harness under in the drivers kick panel to which the alarm sounded and the door finally now opens. This has happened more than 3 times in the last 12 months. The last time I it happened I disconnected and reconnected the battery and it fixed it. I have spoken to the dealer to which they have no idea on the problem. Is there a software issue? I have looked online and found that there are other people with this issue. Any ideas
Old Mar 31, 2015 | 03:24 PM
mrfixit's Avatar
Well if you wiggled the wire harness you triggered something. a bad connection in a plug?? do more investigating.
Old Apr 1, 2015 | 05:17 PM
Check where the harness goes into the door. The flexing of the harness at that point can result in a broken wire.
nut430
Jul 16, 2014 02:43 AM
spyder
Mar 24, 2014 03:18 PM
dakotajw
Sep 23, 2011 05:21 AM
Husky35
Apr 30, 2009 04:16 AM
bourquepa
Dec 5, 2005 10:32 AM
