94 lhs spark problems
Old Nov 29, 2013 | 06:25 PM
texml's Avatar
Default 94 lhs spark problems
so the car ran great Tuesday night Wednesday morning will not start
checked the plugs they are soaked in gas, cleaned them off and check spark it was very weak and eradicate changed the cam sensor and coil pack still getting the same thing any help on what to do would be great
Old Nov 30, 2013 | 09:58 AM
Get the codes. A '94 would be an OBD I system.
Go from there.
Old Nov 30, 2013 | 10:22 AM
texml's Avatar
Go from there.
done that only got a 12 which is a battery reset
which is why im stumped and because it wont start i cant get it to show me any new codes i assume
Old Nov 30, 2013 | 10:45 PM
Make sure the battery is well charged.
Check the wiring in the ignition circuit for loose connections, corrosion, broken wires.
Check for dampness in ignition wires. How old are the plug wires?
Make sure the spark plugs are good and properly gapped.
Old Dec 1, 2013 | 12:54 AM
texml's Avatar
after countless hours on the web i came across a way to test the 4 wires going into the coil 1 is a power the other 3 pulse telling that coil to fire 2 of them are reading almost no voltage with the 3 rd reading about 10v on the pulse what would cause this ? the computer? if so do i need to have it flashed when i replace it ?
but yea checked the wires and plugs they are good so im still stumped changed the tps map and crank sensor today also still no run
Old Dec 5, 2013 | 12:31 PM
texml's Avatar
anyone ??
Old Dec 8, 2013 | 11:37 AM
consideringapacifica's Avatar
Are the cams turning? How old is the timing belt? Start with the basics.
Old Dec 8, 2013 | 01:06 PM
texml's Avatar
yea brought it to TDC and checked timing marks they are right on the money
belt looks to have been changed does not look old or worn at all
WillQRose
Oct 18, 2018 07:18 PM
texml
Nov 30, 2013 10:55 AM
austin
Cirrus & Breeze
Sep 16, 2012 09:09 PM
tginley
May 2, 2010 12:34 AM
robc452
Feb 15, 2007 06:31 PM
