bad water pump???
Old May 18, 2014 | 10:01 AM
Brian87gt's Avatar
Default bad water pump???
About 3 weeks ago my daughters 2004 sebring started making a whining noise from the front end. Just yesterday the car started overheating. The top hose felt hot, and the bottom hose felt ice cold. I figured it was a bad thermostat, but the car has no heat. That makes me think it's 5 he water pump. Do water pumps make noise when they are on their way out? Is it possible to replace the pump without changing the timing chain? I don't really have the time to replace the timing chain. Thanks for the help.
Old May 18, 2014 | 10:10 AM
Noise is typically a crunching or rattling sound .
And sure U can replace just the pump but the chain still has to come off to get the pump out. IS the coolant low?
Old May 18, 2014 | 10:14 AM
Brian87gt's Avatar
So either way the intake and valve covers have to be removed?
Old May 18, 2014 | 12:18 PM
yep no way around it Check that coolant level first IM sure its low then put a pressure tester on it and see where its leaking from.
Old May 18, 2014 | 12:24 PM
Brian87gt's Avatar
Thanks. Is there a how to anywhere on here for this?
Old May 18, 2014 | 09:08 PM
have no idea its not for the fain of heats I can assure u, If buy a manual and go from there see all of what it entails and then decide if u want to do it on have a pro.
Old Oct 29, 2014 | 06:03 PM
94Voyager's Avatar
Hello.
Can you tell me what the circular port on the left in the picture below is for? The old water pump I had doesn't have that port, and the new one (with the port) simply has a plug in there.
I am interested in what that port might be used for, and why it's there.
thanks!
mikey
Brian87gt
May 18, 2014 12:09 PM
bikerbrad
Oct 7, 2011 06:21 AM
dmbeale
15
Nov 24, 2010 06:26 PM
jtminnc
Oct 31, 2010 07:08 PM
captain catfish
Oct 2, 2010 04:32 PM
