Chrysler Grand Voyager Manual 02 Gearbox
Old Oct 27, 2009 | 03:17 AM
Lushy's Avatar
Default Chrysler Grand Voyager Manual 02 Gearbox
Hi, When I am changing gear or sometimes when I am in gear if I press the throttle too hard all I get is lots of revs. I need to be gentle on the throttle in order for the gears to engage. 3rd gear is also a little stiff, are these problems connected i.e. is my gearbox or something related on it's way out? Thanks
Old Feb 3, 2016 | 06:19 AM
chrysler1's Avatar
Whats the mileage. Have you been changing the gearbox oil as per spec. Some people do not realise that the gearbox oil has to be changed. Most manufacturers fit gearbox oil for "life".
Old Dec 8, 2016 | 03:27 PM
Voygerboy's Avatar
Hi change the gearbox filter and gasket which is less than £20 on flee bay and change your transmissions fluid atf+4 I had this on a old 98 3.3 and its been sweet since make sure you put atf+4 as ordinary atf is not correct for the voyager regards Paul
Old Dec 9, 2016 | 02:54 PM
Scotsman4th's Avatar
Think the OP was looking for help with a manual box, not auto.
Old Dec 10, 2016 | 05:40 AM
chrysler1's Avatar
If its a manual gearbox then is probably 99% clutch slip.
Either worn friction plate or damaged pressure plate.
lewisprime
Feb 10, 2016 09:31 AM
chrysler1
Feb 3, 2016 11:20 AM
andyeastsussex
May 5, 2015 11:57 AM
Trevor Barnard
29
Dec 4, 2013 10:15 AM
dcm1971
Oct 13, 2008 03:35 AM
