Fuel filter leaks
Old Jan 20, 2022 | 08:14 AM
Wd08ctc's Avatar
Default Fuel filter leaks
Hi there I have a 1996 Chrysler intrepid 3.3l that has developed a pretty bad fuel leak by the inline filter (tank side) the steel line turns to a braided line close to the filter which then connects to the filter and it's leaking right out of that point. Does the braided line have a o ring in it?
Old Jan 21, 2022 | 09:23 AM
After 25 years the braided line probably needs replacement.
Old Jan 21, 2022 | 01:34 PM
Wd08ctc's Avatar
So I took the old filter off and checked inside the hose and the o ring looked fine so I just replaced the filter to see what would happen and leak fixed so I'm assuming the filter was pretty much blocked and it was causing a back pressure which in turn caused it to leak
dmbeale
Apr 29, 2018 11:02 AM
David gossett
Jun 30, 2017 06:50 AM
Nick1981-1
Jan 30, 2015 10:49 AM
Nick1981-1
Jan 29, 2015 02:09 PM
donnyohs
Jun 1, 2009 10:36 PM
