Help. 2000 Chrysler circus 2.4
Old Jun 12, 2017 | 01:55 PM
tr5211's Avatar
Default no one has a solution!!!! 2000 Chrysler circus 2.4
chrysler cirrus 2000 2.4 100,000 miles
when I try to start the car it just cranks-- when I try again it starts- I put a spark plug tester between the coil and the plug no spark the first time but I do the 2nd time --I replaced the crank sensor and cam sensor and it's the same where do I go from here is there a relay in the fuse box?
Old Jun 15, 2017 | 10:56 PM
what are the codes in the computer?
Old Jun 16, 2017 | 09:35 AM
tr5211's Avatar
There was 2 codes crank sensor and small evap leak it starts if I keep cranking with the spark tester on between the coil and plug no spark unless I keep cranking the engine thanks for responding
Old Jun 20, 2017 | 01:09 AM
replace the crank sensor
Old Jun 21, 2017 | 08:40 PM
tr5211's Avatar
Old Jun 23, 2017 | 01:03 AM
ok then what is the code for the crank sensor just because the word crank sensor is in it does not mean that the issue. Need code number.
Old Jun 23, 2017 | 03:40 PM
tr5211's Avatar
Default 2000 cirrus
The two codes are po340 and po391 I replaced both an stats hard like I said I Put a spark tester between the coil and plug and no spark unless I keep cranking then if I let it sit for a half hour same problem it's not fuel because I sprayed ethanol and same problem once the spark shows it starts
Old Jun 24, 2017 | 12:26 AM
p0391 is not a valid code Look at the crank sensor wires are they full of oil?
Old Jun 25, 2017 | 07:04 AM
tr5211's Avatar
Default Cirrus
no the wires are dry
s.wilson1978@yahoo.com
Jul 12, 2011 02:19 PM
daryls377
11
Jun 12, 2010 09:02 AM
alfman123
Aug 14, 2009 10:19 PM
elbocoupe
Nov 18, 2005 08:30 PM
