help my key (fob) will not work
Old Aug 26, 2013 | 10:42 AM
meggyb's Avatar
Default help my key (fob) will not work
I have a 2010 Town & Country, and the fob buttons work (lock, unlock, etc), but the key will not turn the ignition over. Does anyone know what I could do to try to fix this? I called the dealership and they said they could give me a new one for $250. I bought it used last year and I do not have a warranty on the key. My husband uses the spare, so it is very inconvenient to share his.
Thank you for your help!
Old Aug 27, 2013 | 09:34 AM
Leedsman's Avatar
The key must mechanically fit the lock and be the right miniprogram in the transponder.
If the key will not turn mechanically, it's prob. worn. Try " jiggling it a bit".
If the key turns mechanically but nothing happens, you will have a failed transponder. There is more evidence for this as you have another key that works. It communicates magnetically with an h.f. magnetic field, which also powers the key (hence no battery in the key itself). If you've had the dead key near a strong powered magnetic field, the key could have got blitzed.
The fact you have a working key is good. There are people around who will copy them -- for a fee. They know the manufacturers charge a lot, so the fee won't be pennies. Check Google and E-bay.
On some cars, you can program the key yourself; the car communicates with the key under a special method, and writes the correct program for you. Check into this because it's Chrysler's philosophy to help by putting ercos onto the green display by a special method, so they might have a procedure for writing a key.
Otherwise it's the dreaded dealer price.
Don't grumble too much however, you could have to fork out £500 for a BMW key.
Leedsman.
Old Aug 28, 2013 | 09:47 PM
Before you try anything else, take the key off your key ring and try it in the ignition with no other keys in the vicinity. Some times people carry several keys plus a SpeedPass and other things on their key rings that can confuse the system. Doesn't cost anything to try that.
Old Sep 4, 2013 | 12:22 PM
Breaking300's Avatar
Wow, I never thought about that!
darkwing
Oct 31, 2019 12:37 AM
T&CMAN
Oct 11, 2011 12:18 PM
Ming the Merciless
Apr 9, 2011 12:50 PM
Jacky
Aug 18, 2008 12:30 AM
Guy_laister
Mar 18, 2008 02:19 PM
