How to drop spare tyre of Voyager
Old Dec 21, 2017 | 02:59 AM
paai's Avatar
Question How to drop spare tyre of Voyager
I have bought a Voyager from 2007, and I can't figure out how to lower the spare wheel.
The wheel hangs behind the rear axle, and it normally is lowered by turning a bolt inside the loading space, located five inches from the rear lock, slightly off center to the left. There should be a hole in the floorboard to access that bolt. I had two similar vans before and that is how it works.
In my van the floor is uninterrupted where the hole for the bolt should be. And no, the wheel is not in its alternative location underneath the front seat with a bolt in front of the center console between the seats. I intensively searched the internet, but no solution. Much head scratching ensued.
I can take out the floor board and check, and eventually drill a hole in the board but that is rather a lot of work, because you have to first remove the inside panels. Also, should I assume that in the last ten years nobody had to change a tyre on this car?
Anybody heard of an alternative location for the said bolt?
Thanks.
Old Dec 21, 2017 | 07:34 AM
REBEL59's Avatar
If you can plainly see the spare mounted behind the rear axle, the nut inside the cargo area is in basically the same position as older models(carpeting and lower hatch sill may need slight movement to find). BUT they added a SAFETY latch on the underside of the cable lift mechanism that LOVES to rust up and not release properly to lower the spare. A long shank screwdriver and hammer will be needed to tap on the unit to physically move it to the release position and allow the tire to lower.
IF you have rear seating that folds into the floor(STOW and GO), the spare is mounted underneath BETWEEN the front seats(some use a plastic shield cover that the tire sits in. Operation is much the same to lower it. Only that there is a cover in the console trim between the front seats to remove to access the square drive lift mechanism lug. Tools for such are in the left rear storage compartment.
Old Dec 21, 2017 | 07:44 AM
paai's Avatar
Hi Rebel, you may well be right, but I have no way to check the safety latch either, because there is no access to the nut that lives (presumably) under the floor board. The car is just a van, without seats exept for the driver and codriver,
I added a picture.
Old Dec 21, 2017 | 08:13 AM
REBEL59's Avatar
Thanks for posting the picture , clears things up nicely. Looks to me like a previous owner did a rather nice flooring modification, and did not leave the normal BARE floor or carpeting access spot.
I assume your location is in the Netherlands(NL), as our US cargo versions come with bare metal flooring or carpeting. Good luck on some unwanted disassembly of that wood flooring.
EDIT: Only other suggestion is to go underneath and see if the spare is secured by a carrier BOLT from underneath(like on some other makes of vehicles) Owners guide book should also give you the info you are seeking.
Chrysler Forum Editor
Dec 2, 2012 07:59 AM
chrisunwin
Jun 7, 2012 06:10 AM
Sebring Scot
Oct 6, 2011 12:48 PM
andrew65
Jan 23, 2009 07:43 PM
rdw2606
Apr 15, 2008 02:54 AM
