Intermittent stall.
Old Oct 23, 2019 | 10:29 AM
ooberops's Avatar
Default Intermittent stall.
Hi, I have looked over the forums for a while, maybe its there, but I could not find what I was looking for. I have a 1996 Chrysler Concorde, this is my first Chrysler. I bought it from my uncle and it had some problems, the inner tire rod ends and power steering hose leak. I fixed those and enjoyed the car for a year or so. Then apparently the car would suddenly die every so often, every couple of weeks. Sometimes it turns right back on, sometimes I have to park it and wait before it will keep running. Seems to have something to do with the temperature... When I do errands and things and go from place to place stopping and starting several times is when it gets bad. I looked online and found some similar problems and found no solutions so I started throwing parts at it. New crank sensor, new cam sensor, new ignition coil pack, new wires and plugs, new fuel pump and filter, new fuel pump relay. I don't know what else to do. The crazy thing is there are absolutely ZERO codes. I bought a scanner and now I am trying to catch it in the act. I like the car. It is very clean, everything works on the inside. I want to keep it but this problem is driving me crazy. The only other thing I can think of is maybe there is a vacuum problem, maybe the brake booster. I don't know about common problems with Chrysler like i do GM. Does anyone know what the problem could be? Please help.
Old Nov 12, 2019 | 09:52 AM
ooberops's Avatar
ok i finally caught the problem in the act with my scanner tool and it says p1391 Wheel Speed sensor 1 - g. Most code repositories say it has something to do with the cam and crank sensors but they are both new and are not grounding out. I am going to check the sensor on the transmission. The sub frame bushings and trans mount were virtually non existent and the whole assemble moved around a lot, I wonder if the the wires are ok. I will also check the wheel sensors on all the wheels. Hopefully i will find something.
Full Nelson
May 27, 2013 04:54 PM
01 blues
Aug 21, 2010 12:23 PM
mshgturner
Dec 12, 2009 06:44 PM
bcartman_2
Jul 30, 2009 07:34 PM
jremmi
Cirrus & Breeze
Oct 22, 2008 07:28 AM
