no reverse and backfires!!!!!!!!!!!!!
Old Oct 13, 2007 | 05:44 PM
  #21
peterjb44's Avatar
Default RE: no reverse and backfires!!!!!!!!!!!!!
lol, no problem.
that makes sence to me, it was strange to just go without any notice, i did think it was a blockage, i have had a friend look at it, he says he can hear it engage then come out!!, he was going to take it off and strip and clean the tranny, but, then found out it will need recalibrating (training), i have also read the manual and it also says if the valve body is changed/reconditioned then it also needs recalibrating, i have removed and cleaned the valve body and the car seems to drive the same, will it need recalibrating or will it only need recalibrating if there is a problem (ie. not smooth upshifting/downshifting etc...) after parts are changed.
can it only be put into training mode with a scan tool??
peter
Old Oct 13, 2007 | 06:28 PM
  #22
peterjb44's Avatar
http://img.betchuk.com/thumbnails.ph...=10&page=5
what picture number has the part #51 in?
Old Oct 13, 2007 | 07:20 PM
  #23
peterjb44's Avatar
omg, i should have checked the low/reverse accumulator piston and springs when i removed the valve body,
this guy had lost reverse, he had no friction material left on his reverse clutch pack and one of his accumulater spring was broken.
http://img.betchuk.com/displayimage....=12&pos=14
http://img.betchuk.com/displayimage....=12&pos=35
tomorrow i'm gonna remove the valve body again and check the low/reverse accumulater piston and springs, well i've got nothing to lose (damm, i should have checked it before, lol), if i have got a broken spring then i hope i've still got friction material left on my reverse clutch pack,lol. or its gotta come off
any way i will keep you posted
peter
Old Oct 13, 2007 | 07:41 PM
  #24
moe's Avatar
moe
cool pete, what your talking about is called quick learning the trans ,thats after you rebuild the trans you need to reset the clutch volumes.if you drop the pan look for metal in the pan. i wouldn't touch the valve body.just drop it down make sure the lever is in the park position before you drop the v body will make it alot easier.other wise the rod will hang up when you drop it.talk to you later.moe
Pj White
May 18, 2013 08:59 AM
DanNotTheMan
Sep 28, 2012 09:15 AM
Shagasaur
Cirrus & Breeze
Mar 22, 2012 04:51 PM
tonywhite
Aug 21, 2008 11:57 AM
TandC
Mar 12, 2006 05:26 AM
