Please for the love of God how do I turn off the seatbelt alarm never never stops
Old Apr 20, 2021 | 11:33 PM
Lauren LeMay's Avatar
Default Please for the love of God how do I turn off the seatbelt alarm never never stops
I’m going crazy how do I turn this damn thing off once and for all I want to disconnect it completely if I drive for two hours without a seatbelt the alarm keeps ringing for two hours, I’m tired.
chrystler town and country
2015
The loudest car I ever owned and the most stressful and annoying thing I’ve ever experienced in my whole life. Where is the fuse how do I burn it.
Old Apr 21, 2021 | 09:12 AM
calamity coyote's Avatar
Put on your seatbelt and it will stop. It's a safety feature required by law and no one is going to tell you how to bypass a safety feature.
Old Apr 21, 2021 | 01:48 PM
Nehmo Sergheyev's Avatar
2015
This should work for a 5th Generation (2008-2016), which you have.
Under the driver's seat there is a yellow connector with a red rocking slider tab. Pull out the red rocking slider and push the yellow latch toward the connector's case, thereby disconnecting the connector. Hold the female part of the connector with the latch up and the female-pins (set in blue plastic) facing you.
With a 1/2 inch piece of solid coper wire, make a U shaped jumper. Use the jumper (insert it) connecting the 2 right-most wire connectors. You also can connect the 2 wires by other means. The sound alarm should now be disabled.
Report back with your results.
Old Apr 22, 2021 | 08:17 PM
ggoose's Avatar
I must agree with calamity coyote - BUCKLE YOUR D*** SEATBELT
It is obvious that no argument will convince you otherwise so I suggest you get some personlized license plates that read ORGN DNR
And leave God out of this, it is all you
\rant off
Kenny Jones
Apr 30, 2018 07:43 PM
maintenance
Apr 23, 2015 03:52 PM
passingthrough
Jan 26, 2015 04:16 PM
paulak412
Jun 4, 2014 02:10 PM
momoyan
Feb 19, 2010 11:58 AM
