Stratus Engine Swap - shuts down after a couple sec.
hey gold .i just had this same problem today at work,the guy puta junk yard pcm in the car.well once the vin #is burned into a pcm you can't change it .he'll need a pcm for starters.the engine sway is another thing totally ,not to meantion the different fly wheel.wow!! moe
when you swapped out the pcm you probablynow told the vehicle that it has an alarm in it when it dosent. try putting the old pcm back into the vehicle. BUT if the BCM learned that it has an alram from swapping them out you may have to replace both the pcm and bcm if this is the problem.
Your best bet woul be get a scan tool and see what the vehicle is doing when it cuts off. replay back at damnnickname@yahoo.com
2000_300m
Apr 24, 2014 01:06 AM
andbudzi
Feb 20, 2008 04:07 PM
