Stratus Engine Swap - shuts down after a couple sec.
Old Sep 14, 2007 | 09:11 PM
Default RE: Stratus Engine Swap - shuts down after a couple sec.
calm down gold the car he has does not have skim so your last post does not apply.
Old Sep 15, 2007 | 12:25 AM
Gold Cruiser's Avatar
I appologize for that. That's why I said, I would think that it applies for his vehicle. I stand corrected. It won't happen again. Thanks for the info.
Old Oct 22, 2007 | 07:17 AM
cenzo's Avatar
How about the steering wheel lock?
On my "other" car, if the engine starts and the steering wheel is locked, the fuel shuts off so you can't drive (GM).
Old Oct 22, 2007 | 08:59 PM
moe's Avatar
moe
hey gold .i just had this same problem today at work,the guy puta junk yard pcm in the car.well once the vin #is burned into a pcm you can't change it .he'll need a pcm for starters.the engine sway is another thing totally ,not to meantion the different fly wheel.wow!! moe
Old May 30, 2009 | 12:32 PM
  #15
Lyndav's Avatar
Did you new engine act the same way as the old engine when you replaced it?
Old May 31, 2009 | 10:34 PM
  #16
Chrysler258's Avatar
I think, they must be similar
Old Jun 8, 2009 | 01:35 PM
  #17
maxpower's Avatar
when you swapped out the pcm you probablynow told the vehicle that it has an alarm in it when it dosent. try putting the old pcm back into the vehicle. BUT if the BCM learned that it has an alram from swapping them out you may have to replace both the pcm and bcm if this is the problem.
Your best bet woul be get a scan tool and see what the vehicle is doing when it cuts off. replay back at damnnickname@yahoo.com
jec32
Nov 25, 2020 11:52 PM
RacingJunk
Jun 18, 2014 01:08 AM
2000_300m
Apr 24, 2014 01:06 AM
Milliwatt
Jun 4, 2012 03:39 PM
andbudzi
Feb 20, 2008 04:07 PM
