K-Cars Talk about the infamous K-Cars within.
changing wheel studs on a 92 lebaron
Old Sep 9, 2006 | 03:06 PM
dws's Avatar
dws
Default changing wheel studs on a 92 lebaron
i need to find out how to change the front wheel studs on a 92 lebaron sedan.
thanks
Old Jul 19, 2008 | 01:17 PM
chief's Avatar
Default RE: changing wheel studs on a 92 lebaron
First you remove the wheel, remove caliper guide pins then remove the brake caliper, suspending it from the coil spring. Next remove the rotor (may have to remove retainer washers).You then remove the cotter pin, keeper and axle nut. The axle might need tapping out thru the hub/bearing center hole then remove the hub. This you will probably need to take and have the old lug removed and new one pressed into the hub. Replace in opposite order you removed.
ettienne
Apr 25, 2011 02:09 PM
ikester
Oct 5, 2010 02:36 PM
jamgratz
Jan 9, 2009 06:45 PM
NisCAPE
Jun 22, 2008 04:24 AM
wardncr
Nov 16, 2007 01:17 PM
