03 T/C A/C not cold below 2000RPM
Old Jul 26, 2015 | 10:43 AM
Wheelman_60's Avatar
Default 03 T/C A/C not cold below 2000RPM
My 03 Town&Country AWD 3.8l does not put out very cold air below 2,000 RPMs. Also; the previous owner said it may overheat when idling with the A/C on. I checked the low-side freon pressure (engine on and A/C on max) with a store-bought kit; it reads in the red, like it's overcharged. The compressor makes a sort-of groaning noise in tune with RPMs when its clutch is engaged. I don't see a lot of debris on the condenser. I think the radiator fans aren't kicking in when they should in order to pull cooler air across the condenser. Any advice for what I can do before spending the $$$ to take it in would be much appreciated.
Old Jul 26, 2015 | 02:30 PM
If it's overcharged, then the first thing to do is get the charge correct.
The fans are controlled by the engine computer and turn on when certain conditions are met. To know if they are working properly you need appropriate testing equipment that can read engine coolant temperature, etc.
You can jump the fan relays to see if the motors work.
dazzzzbo.uk
11
Sep 9, 2014 05:26 PM
Ephata
18
Jun 4, 2014 02:14 PM
DaveSiever
Jun 3, 2014 03:23 PM
hoef
Mar 23, 2011 11:17 AM
Chrysler group
Feb 15, 2010 03:58 PM
