brake sticking on my 98 voyager
Old Jun 7, 2009 | 03:13 PM
wako's Avatar
Question brake sticking on my 98 voyager
ive changed pads, discs, calipers, hoses and master cylinder and still have problem can you help
Old Jun 8, 2009 | 12:27 PM
Does it have ABS? Could it be a problem with the control unit?
I assume you are dragging a front brake so it's not a problem with a corroded parking brake cable.
With all the things you have mentioned, the only other things involved in the braking action are the pedal and the caliper brackets. Inspect the brackets carefully to make sure they're not notched or worn and are properly lubricated. They don't do much other than sit there and resist movement.
Make sure the pedal is free to move and doesn't have a left foot riding on it. (It happens.)
Old Jun 9, 2009 | 04:52 AM
wako's Avatar
Default Brakes sticking
I have found it to be a little module which is fitted to the inner wing next to the fuse box under the bonnet were there is a small breather pipe coming off the servo to it then another pipe from that to the back of the engine I have taken the pipe off the module yellow in colour and it seems to be fine but now need to find the relay or fuse to the module the yellow pipe is just sucking air in now can you help
Pop45
Mar 16, 2014 08:39 AM
David Rovka
Sep 22, 2013 07:09 PM
smartobject
Oct 30, 2009 11:19 AM
barrybb
Jun 2, 2009 03:42 PM
yorto
Dec 30, 2008 12:27 AM
