Miss fire problem
Old Sep 15, 2015 | 01:40 AM
Sailorbo32's Avatar
Unhappy Miss fire problem
I have an 02 dodge 1500 4.7L, I had a P0304 code, then a P0354, I checked the plug it was gunky and wet. i changed the plugs, it was time anyway, Cylinder 4 and 6 were gunky and wet, still missing, changed the coil on 4, still missing. I've tried changing injector, intake manifold gaskets, and loosening the exhaust flange, still misses. Did a dry compression test, was getting 120 psi. still missing. I checked the plugs again, 4 and 6 were wet with gas and starting to get gunky again.
Any suggestions?
Old Sep 15, 2015 | 06:01 AM
claytonncguy01's Avatar
Smile gunky wet sparkplugs
Hi it sounds to me that one or more injectors are not shutting off. check fuel regulator,fuel pressure and when you did a compression test 120 across all cylinders? how many miles does the car have? good luck
Old Sep 15, 2015 | 09:28 AM
Sailorbo32's Avatar
just over 200,000 miles. I've been told It might be the computer or the piston rings. I'm not entirely convinced it's the computer
Old Sep 15, 2015 | 02:56 PM
do a google on code p354 u will see its not piston rings
Old Sep 16, 2015 | 12:12 AM
Sailorbo32's Avatar
So after new plugs, a new coil, new injector, new intake gaskets, engine still runs rough, missing, I can hear a tapping while running, Cylinder 4 and 6 plugs will be gunky when I remove them, when I changed the intake gaskets I noticed that the intake on cylinder 4 and 6 were dry as the rest were wet. what else can possibly be causing miss fire?
Old Sep 17, 2015 | 10:41 PM
valve spring
snake7247
Apr 28, 2014 11:14 PM
Mick
May 31, 2013 05:57 PM
nicksmith
Feb 14, 2013 02:57 PM
marko500
May 4, 2011 02:31 PM
nick v6
Aug 9, 2010 03:16 AM
