Problem with Solenoid Transmission Valve
Old Jun 26, 2018 | 02:29 PM
Freccia's Avatar
Default Problem with Solenoid Transmission Valve
Hi,
i've got a Chrysler Concorde 2004 VIN: 2C3HD46R74H674849. I have some problems with the solenoid valve. Sometimes not always the engine light come up and when you go under 20miles the transmission got stuck in second gear. I already diagnostic the problem and it is the solenoid valve.
I just would like to know how much cost just the labor to replace that (just the mechanic job), and if the transmission has to be disassembled all for change the valve or it is external and doesn't need to be disassembled.
If somebody can halp me i appreciate that so much!
Stefano
Old Jun 26, 2018 | 06:19 PM
FIREM's Avatar
Solenoid pack can be changed by dropping the trans pan, then the valve body. "Book Time" is about 2.5 hours. Reminder to only use ATF+4 in that trans.
Labor rates vary but figure on filter and about 8 quarts of fluid as part of the cost.
Old Jun 27, 2018 | 11:51 AM
Freccia's Avatar
Thank you so much FIREM. You have an idea of how much could be the labor? Bc i saw online the part and i can find it for 150/160$. I need just to know the labor price (more and less).
Thank you again.
Ste
Old Jun 27, 2018 | 03:31 PM
FIREM's Avatar
Varies by location, average auto rate in my area is $100 per hour.
So $250 Labor, Ball park $100 fluid & filter & misc.
Expect to pay $350 ish.
Old Jun 27, 2018 | 03:40 PM
Freccia's Avatar
And i don't need to buy a new solenoid valve??? Or change ball park, filter & misc are enough???
Thank you so much!
Ste
Old Jun 28, 2018 | 05:45 AM
FIREM's Avatar
I figured you already had purchased the solenoid. Here is what I did to one of my 300M's
Installed a Remanufacutred Solenoid from TRANZMISSION PARTS USA. $49.99, lifetime warranty, even came with a new gasket, good to go. (EBay) Figured that the Pro-Am is my daily "truck" and trying to keep it on the road, on the cheap, took a chance on the reman, with good success.
Have about 10k miles since repair and all is well.
A few others at the 300M site have used this reman solenoid with no issues.
67 Camaro
Jan 6, 2015 08:40 PM
Skidazl
12
Aug 16, 2014 10:29 PM
seizure later
Oct 4, 2012 10:31 PM
leeb
Jun 22, 2011 07:03 PM
mflorence
Feb 17, 2011 01:41 PM
