Timing question
Old Jul 14, 2018 | 11:36 PM
Sebring1988's Avatar
Default Timing question
Hey all, having issues with a few things.
so I am replacing the water pump in the 04 sebring 2.7l, I have the timing cover off and everything I am suppose to. I found what I thought was the correct links for the chain, and what I thought was the correct Mark's on all the gears, replaced the water pump and timing chain tensioner, and reassembled the timing system and I was verifying before I put the cover back on by rotating the crank manually. When I do this I can watch the tensioner guide move back and forth, and the tensioner makes a loud clicking sound. Almost like it activates and then deactivates, you can watch it do it too.It does this at the same interval every time I rotate the crank. Is this suppose to sound like that? This is my first experiance with a tear down on this engine. Advice would be appreciated. Also help finding the colored links on the chain would be helpful as well.
Old Jul 16, 2018 | 11:37 PM
the tensioner is spring and hydrologic they make noise untill the oil pumps it up
skip to 16 min
Diego1980
Apr 3, 2018 11:59 AM
jimG
Aug 24, 2016 10:24 PM
xmanmta
Mar 7, 2016 06:55 AM
Treefrog
Feb 10, 2012 09:46 AM
brianisme
Dec 9, 2009 02:29 PM
