Tps problem
Old Apr 27, 2018 | 11:48 AM
Scott Vogt's Avatar
Default Tps problem
Hi i'm working on a 03 Chrysler town and country 3.8 and I'm not getting 5 volts from the pcm for the tps sensor it's only 3.5 to 3.7 coming out what could be the cause of it I have a new pcm (same reading as on one) ,cam/crankshaft sensor and tps.
Old Apr 27, 2018 | 12:35 PM
Scott Vogt's Avatar
Tps as in throttle position sensor
Old Apr 28, 2018 | 10:07 AM
REBEL59's Avatar
Start at your basic electricals , test the battery and make sure the ground connections at battery, engine block and chassis are CLEAN and tight.
Old Apr 28, 2018 | 12:10 PM
Scott Vogt's Avatar
Grounds are good
Old Apr 30, 2018 | 03:50 PM
Scott Vogt's Avatar
Anyone?
Old Apr 30, 2018 | 05:37 PM
REBEL59's Avatar
How old is the battery and you need more than a volt reading..you need proper available amps also.Sounds like you need to start checking wiring for corroded connections, if I understand that other sensors are giving the same reference voltage by your posting.
Again check your ground cables from battery to motor and battery...They may LOOK ok but may be corroded on the fastening side of the eyelets. Good Luck!
Old Apr 30, 2018 | 05:54 PM
Scott Vogt's Avatar
I check the ground from end to end battery is new my problem is I can't get the car started and cam,crank,tps etc sensors are coming up on cell codes and they all been replaced and I check each wiring for fried or broken wires
jdsaengine
Jun 15, 2009 04:15 PM
zimba
Jun 10, 2007 09:50 PM
tmp03tnc
Mar 29, 2006 04:19 PM
davesan
May 13, 2005 07:05 AM
electrocuda
K-Cars
Apr 21, 2005 07:06 PM
