Other Any other Chrysler within.
1988 lebaron issues
Old May 29, 2016 | 10:20 PM
TENNO89's Avatar
Unhappy 1988 lebaron issues
It has a 2.2l turbo. Auto. Low miles. It has new wires, plugs, timing belt, distributor cap, distributor pickup, coil, rotor button, injectors, fuel pump.
Tdc was set. The marks on th wheel wer set so th cam was lined up. It'll act like it wantsta start....it'll spit n sputter.....but wont start.
Any ideas???
Old May 30, 2016 | 11:23 AM
bridanne's Avatar
1. Check the compression
2. Check the firing order
3. Make sure you are getting fuel to the intake
4. Make sure you do not have an obstruction in the exhaust.
Old May 30, 2016 | 11:47 AM
TENNO89's Avatar
All tht has ben done. I'm gona put on a new map sensor next. Process of elimination i gess
Old May 30, 2016 | 12:03 PM
bridanne's Avatar
Have you pulled the codes with the key and watching the check engine light.
Old May 30, 2016 | 03:06 PM
TENNO89's Avatar
Dunno wat u mean "pulled th codes with th key"
Old May 30, 2016 | 03:42 PM
bridanne's Avatar
To pull the codes on the early models like you have you can do it by doing what is called the key dance. All of the key codes are 2 digits and are flashed by the check engine light. To do the key dance it is done this way: turn the key on then off then on then off then on with no pauses.
Old Sep 5, 2016 | 03:40 PM
scarbro2011's Avatar
I would pull a spark plug and see if it is wet or dry. Wet - fuel is there but no spark.
Dry - no fuel and possible no spark. Turn the key on to the "RUN" position and listen for the fuel pump running. Check the fuel pump fuse. And I assume that there is fuel in the tank? Don't laugh. I've been there a couple of times with an empty tank.
Also use the timing light to see if it triggers when the engine is turning over.
You may also have have a ECU/ECM (Engine control unit/module) problem.
Regards and POR - Press On Regardless
Bob
TENNO89
May 28, 2016 11:08 PM
Steaknyfe
Aug 16, 2012 09:35 AM
Erivaj
Other
Aug 22, 2011 04:25 AM
bobg1227@yahoo.com
Sep 23, 2010 04:36 AM
