98 Concorde 3.2
No start :( she drove it home yesterday. Engine turns over but that is it. Had a code back in june.. Code PO306 replaced all the spark plugs and one coil pack. I just put in a fuel pump relay. Still won't start :( Ideas?
missing spark or fuel see which one
No spark. Just got the chance to check!
No power to 2-20 amp fuses in fuse and relay center. 20 amp inj/coil and 20 amp ASD
Anything?
ok which fuses there are many 20 amp fuses
The ones listed above ASD and
helps out zero not infront of the car to see this. look under the cover and tell me what the fuses are designated to
The 2 20 amps on lower left. https://i179.photobucket.com/albums/...A6E15620D4.jpg
the asd only has power on it when the car is running or it is starting it will not supply power to the injectors or coil unless it cranking.
