98 Concorde 3.2
Old Jul 25, 2015 | 03:40 PM
SeanTX's Avatar
Default 98 Concorde 3.2
No start she drove it home yesterday. Engine turns over but that is it. Had a code back in june.. Code PO306 replaced all the spark plugs and one coil pack. I just put in a fuel pump relay. Still won't start Ideas?
Old Jul 25, 2015 | 04:04 PM
missing spark or fuel see which one
Old Jul 26, 2015 | 11:57 AM
SeanTX's Avatar
No spark. Just got the chance to check!
Old Jul 26, 2015 | 03:06 PM
SeanTX's Avatar
No power to 2-20 amp fuses in fuse and relay center. 20 amp inj/coil and 20 amp ASD
Old Jul 27, 2015 | 04:52 PM
SeanTX's Avatar
Anything?
Old Jul 27, 2015 | 11:33 PM
ok which fuses there are many 20 amp fuses
Old Jul 28, 2015 | 05:35 AM
SeanTX's Avatar
The ones listed above ASD and
Old Jul 28, 2015 | 01:30 PM
helps out zero not infront of the car to see this. look under the cover and tell me what the fuses are designated to
Old Jul 29, 2015 | 07:16 AM
SeanTX's Avatar
The 2 20 amps on lower left.
Old Jul 29, 2015 | 11:49 AM
the asd only has power on it when the car is running or it is starting it will not supply power to the injectors or coil unless it cranking.
