Wheels and Tires Talk about rims and tires
How often should car tires be changed or have air put in?
Old Sep 22, 2013 | 09:24 AM
bristimjet's Avatar
Default How often should car tires be changed or have air put in?
How often should car tires be changed or have air put in, if usage is for a sedan or wagon and someone that works 9-5 5 days a week (15 miles each time)or less than that, if it really makes a difference.
Old Sep 22, 2013 | 01:12 PM
doug45601's Avatar
Depends on road conditions and driving habits to determine tire wear. Tread wear (deepness of the groves), outer tread rounding or scalloping are all determining factors. Time is not always a factor unless the tires age and have sidewall cracking before they actually have excess tread wear. As far as "airing" is concerned.. Pressure should be checked on a monthly basis if not sooner! Always keep an eye on tires for going flat and even then, just don't air it up and leave it at that! Have it checked out for a leak or puncture. Hope this helps ya..
Old Jul 25, 2019 | 04:04 PM
jtcooks's Avatar
Thanks for useful advice
Old Oct 7, 2020 | 11:25 PM
ggoose's Avatar
As a rule of thumb, tires will lose/gain 1 psi for every 10 degrees of temp change. If you set the tire to 32psi when it is 70 degrees, the tire will read around 30psi at 50 degrees.
Rotate the tires every 7,000 - 10,000 miles will keep the tire wear even. Tire rotation is typically cross to the drive wheels; that is, on a RWD left front goes to right rear, right rear goes to right front, etc. For FWD left rear goes to right front, right front goes to right rear, etc. Of course, if you have unidirectional tires or different sizes on front/rear, this dos not apply.
Old Aug 3, 2021 | 03:33 PM
300Addict's Avatar
Talking "Double X" pattern?
Interesting. What I didn't realize is that there is some judgement made by the mechanic as to the best pattern to use when rotating tires. This article on Columbiana CDJR's site describes a "Double X" pattern for AWD and 4WD vehicles. That patern seems to make sense to me.
ADKNV
May 12, 2015 11:28 AM
Go4Gold
Sep 20, 2011 02:48 PM
adam.davis
Dec 30, 2010 06:48 PM
plnwfyr
Apr 6, 2009 09:36 PM
Skycop385
Nov 15, 2008 07:43 PM
