2.7: Coolant boiling, fans off, Tē gauge in "normal". What happens??. Help!
Old 08-29-2012, 11:51 AM
Denis.V's Avatar
Cool 2.7: Coolant boiling, fans off, Tē gauge in "normal". What happens??. Help!
Hi,
My 2003 2.7 sebring was boiling 3 months ago. Replaced radiator cap and problem finished. Then, 3 weeks starts boiling again. replaced plastic upper water outlet (leaking too) with temperature sensor included ("Dorman" product made in China), and I replaced the failed thermostat too. Problem finished. Yesterday, boiling started again.
Coolant is boiling with temperature gauge at medium position, but fans don't work.
When I connect the air condit. fans work O.K.
When running car with max. heater, coolant don't boils and no problem.
What could be my failure?.
Anny ideas?. Please help. This car is used for my children transportation to school.
Thanks in advance,
Denis V.
Old 08-30-2012, 09:39 AM
make sure fans come on make sure there is coolant all the way to the top of the coolant jug make sure there is no air bubbles in the system.
Old 08-30-2012, 04:15 PM
Also make sure you have the proper mix of water and antifreeze. Too much water or too much antifreeze will cause it to boil at a lower temperature.
If you have a blown head gasket, it could cause boiling, or if you have installed the thermostat backwards, it could overheat rapidly.
Old 09-04-2012, 08:26 PM
DaleCarol's Avatar
manan
08-09-2019 05:22 PM
HowieF16
10-13-2014 03:49 PM
jayroc7113
04-03-2014 04:34 PM
Lanvale
10-12-2011 05:21 PM
tycho
01-01-2011 07:27 AM
Quick Reply: 2.7: Coolant boiling, fans off, Tē gauge in "normal". What happens??. Help!
