04 pacifica heat
04 pacifica heat
im having a problem with changing from floor to vent & vice versa. i can change it to the floor & it blows out the defroster & very little on the floor. is there a way to reprogram the unit. i have the digital unit.
The blend air actuators are DC servo motors, not vacuum motors.
If airflow is an issue, check/replace the cabin air filter.
The two blend air actuators (one for the front, one for the rear) are indentical components. If airflow is OK, and the problem is airflow direction you could swap the actuators. If the problem moves with the actuator, you've found the problem.
davet
12-19-2007 04:18 PM
