Advice needed-- Clicking noise when stepping on brake
Old 09-05-2009, 01:08 PM
SanDiegoPac's Avatar
Default Advice needed-- Clicking noise when stepping on brake
I replace the brake light bulb and ever since, there is a clicking noise when I step on the brake while the car is in "Park". The noise is a clicking sound that is coming from under the gear shifter. Does anyone know what is causing this?
Old 09-05-2009, 02:15 PM
Sierrasan's Avatar
There is a shifter interlock solenoid in the center console. You cannot move out of park without your foot on the brake. The noise you are hearing is the interlock releasing when you step on the brake. Totally unrelated to changing the bulb
Old 09-05-2009, 03:16 PM
Thanks-- it was just coincidence that this noise just started happening after I replaced the bulb. Since this noise had never happened before I'll make an appointment with the dealership to get it looked into.
Old 09-06-2009, 09:16 PM
Sierrasan's Avatar
Your going to waste your money. This sound is normal.
Old 09-07-2009, 12:23 PM
This sound is not normal and is very loud. Besides it just started the other day, so it must be something differnt causing it. My car is still under the original factory warranty, plus I also have the Max Care Extended warranty, so it will not cost me a thing to have the dealer check it out. When I find out the cause, I'll come back here to post... Thanks.
fifthave92
05-01-2011 10:48 AM
SanDiegoPac
07-17-2009 01:48 AM
Andreas LHS
08-21-2008 09:52 AM
dan_te
09-12-2007 09:25 PM
whitesmirnoff
04-06-2007 01:31 AM
Quick Reply: Advice needed-- Clicking noise when stepping on brake
