No start after H2O pump and timing belt
Old 09-11-2011, 03:53 PM
shaka38's Avatar
Default No start after H2O pump and timing belt
My water pump went bad. I replaced the pump and the timing belt while I was at it. I have 130K on it and did a tune-up at 120K, all but the timing belt. Now that I did the timing belt, the vehicle will not start. I have no fuel at the fuel rail, and it appears that there are no outputs from the PCM.
I've run an Actron scanner and seemingly anything from the PCM comes up as incomplete, i.e. any sensor involved in engine ignition, etc.
I'm at my wits end! The vehicle was running fine before but now no fuel. Is there a reset for automatic shutdown? Pulling B+ isn't cutting it.
Any suggestions anyone?
Old 09-11-2011, 10:51 PM
Go back and check your timing make sure the engine is at TDC to start with
If it was running b4 the work was done and now its not U can bet its human error go look at everything again.
Old 09-12-2011, 10:29 AM
shaka38's Avatar
Roger, Chrysler Tech,
Will do...I'm as frustrated as ever! I'm in the middle of a move to El Paso from WI. I was trying to prep the vehicle for SW Texas.
I appreciate your response.
lost-in-space
Cirrus & Breeze
12-05-2014 10:36 PM
nonhemi1959
11-22-2014 07:18 AM
binky42
Cirrus & Breeze
07-20-2011 06:10 PM
montreal
05-07-2008 10:59 PM
sebringphanatic
03-22-2008 07:57 AM
Quick Reply: No start after H2O pump and timing belt
