Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler PT Cruiser
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 10-06-2011, 03:14 AM
Thumbs down 2003 pt cruiser engine light
I bought a 2003 PT Cruiser Turbo. One month later the engine light came on with codes 0456 and 0517. I took the car in on three separate occasions but I still have the problem. This is what the mechanic checked:
May19: tested purge solenoid - no leaks; tested all EVAP lines with smoke - no leaks; NVLD valve stuck open - constantly venting - will not close when commanded-replaced NVLD-EVAP test ran with MODIS and passed. Light still on.
June 8: Smoke tested and found a vacuum "T" for EVAP broken/cracked-repaired T and re-ran EVAP test with MODIS- passed. Light still on.
August 1: Smoke tested and thoroughly checked for leaks - none found; removed and cleaned EVAP lines of carbon; ran EVAP test with MODIS-passed. Replaced gas cap with new gas cap.
One week later the engine light went off on its own. After one month the engine light came back on.
The mechanic wants the car for two days for further pinpoint testing of EVAP system.
Does anyone have any idea what may be the solution or problem? Thank you.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 10-06-2011, 08:28 AM
TNtech's Avatar
If it came back on after a MONTH, what makes you think it's still the EVAP system? Last I checked there were about 260 reasons it couild come on.
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
Old 10-06-2011, 02:30 PM
I don't have a clue. The mechanic thinks it may be the EVAP system. Do you have a downloadable form that lists those 260 reasons? I am grasping at straws here. Thank you.
Old 10-06-2011, 10:42 PM
TNtech's Avatar
Let me know what the codes are at this time. If it's still P0456 for small leak (we're talking .020") and he really can't find any external leaks, the most likely would be an internal leak inside the purge solenoid. If you're not well experienced in EVAP systems they will eat your lunch. As hard as my job is, I can't imagine being at an independent shop these days. What a cluster that must be.
__________________
Crossfire
Old 10-07-2011, 02:30 AM
Thank you for getting back to me. The codes are still and always have been: codes 0456 and 0517.
I look forward to hearing from you.
Old 10-07-2011, 09:20 AM
TNtech's Avatar
517 is a battery temp sensr high voltage. Not related to the EVAP code. Batt sensor is under the battery tray. May be unplugged. FYI, i've been burned on that 456 for purge internal leak a couple times. Engineer tests many times don't account for certain things.
__________________
Crossfire
Old 11-02-2011, 06:47 AM
Thanks for the help.
__________________
Windshield Replacement Frisco
Tags
0517, 2003, chrsyler, code, cruiser, engine, evap, light, nvld, p0456, price, pt, remove, solenoid, unit
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
