2002 T&C Transmission Problem
My vehicle is a 2002 Chrysler Town and Country with a 3.3L engine. The vehicle has approximately 130,000 miles on it. I don't know if the transmission oil and filter have ever been changed. Yesterday, with no previous problems, a loud whine started while I was driving at about 45 miles per hour. At first I thought it was an ambulance siren. One mile later, the transmission stopped working as if it were in neutral rather that in drive. I stopped the car, turned it off and restarted. It drove for about a mile and then the whine came back and it stopped working again. There are no permanent codes and the check engine light is off. I hooked a scanner up and there are several pending codes- P0700, P0731, P0733, P0734, P0841 and P0846. The transmission fluid is at the proper level. The transmission does NOT enter the limp mode. What should I look for?
Thank you. I was experiencing very similar issues on my UK 2005 2.8 CRD. All of the gear ratio codes plus 0845 and 0846. It would drive fine for a few minutes then gear change problems would start, going in to neutral, engine management light coming on plus an intermittent whine/rattle. I changed solenoid assembly and input/output sensors based on the info I got from the internet/forums etc. Same issues. Changed the filter (and oil) and so far so good. If you look at the Chrysler service A schedule the transmission filter/oil are a none serviceable part! On the B schedule it needs changing approx every 90000k depending on which Chrysler info you read! I bet most cars are probably serviced on schedule A but reading on what classifies servicing it on B I think most should probably be on B.
jan.murawski
05-04-2014 06:52 AM
hunterbaye
06-17-2011 01:44 PM
