Sponsored by:
Sponsored by:
2005 T&C Clunk on braking (drivers side)
Old 04-18-2015, 07:28 PM
dandyd's Avatar
Default 2005 T&C Clunk on braking (drivers side)
Our T&C has a nasty clunk noise from the left front when braking? The struts, the control arms, sway bar bushings, sway bar links, rack and pinion, front transmission mount have all been replaced.....and still the clunk on braking continues....... anything else to consider??
Old 04-19-2015, 03:34 PM
You say when braking but your repairs relate to going over bumps and uneven surfaces.
So your looking at brake caliper issues here. Maybe I say as this fault eludes me at mo. Check your brake calipers for security and pads are intact.
If things get head scratching, disconnect your steering rod ends and try turning your struts by hand as this relates to top strut bearing and is a tell-tail.
Old 04-19-2015, 03:54 PM
Here's another. While wheel on ground grip top of wheel and pull and listen for your clunk. Is it there. Think this is the top strut mount issue. Also as I found when renewing my control arms the front through bolt connecting the arm to the chassis is a rattling fit so tighten it when wheel on ground.
BenjaminA
01-10-2012 04:14 PM
cherrob123
10-21-2011 10:07 AM
Skycop385
06-22-2008 07:41 PM
Nick325is
09-04-2007 08:15 PM
bruce777
06-09-2007 03:41 PM
Quick Reply: 2005 T&C Clunk on braking (drivers side)
