Need help with jumping speedometer
Hello I have an 02 town and country 3.8 motor the other day the speedometer started jumping then the transmission started acting up. I did some research and found that the usual problem is the speed sensor. so I changed both speed sensors. now the transmission is acting fine but the speedometer is still jumpin when in gear and not moving..if you give it gas and start to move the jumping stops. but if you stop at a red light it starts back what else could it be... I have already recalibrated the instrument cluster too thankyou how any hintson other things to check!
almangar
09-22-2012 06:59 AM
