Throttle body cleaning?
Old 03-17-2008, 03:49 PM
lerry1957's Avatar
Default Throttle body cleaning?
When cleaning the throttle body on a 2006 Sebring, should one remove body or just wipe blade and body clean with cleaner and rag? Somebody told me to shoot carb cleaner thru little red straw that comes with cleaner down a little bleed hole just beyondthrottle body butterfly blade. Does this sound like accurate advice? Thanks...
Old 03-19-2008, 09:55 PM
Default RE: Throttle body cleaning?
I dont know alot about the type of fuel system but I thought the only thing going through your throttle body is air and that the fuel is injected into the cylinder or intake plenium by the fuel injectors. Any thing you spray or put directly into the intake is unfiltered. Unless you have a problem with the way your engine runs I would leave it alone. If there is a problem I would try to address the problem Just my 2 cents.
Old 03-20-2008, 02:24 AM
lerry1957's Avatar
Thanks for the reply. Why I ask, the guy at the Chrysler garage told my girlfriend she should have the throttle body serviced/cleaned. The car has 45000 miles on it and he said if she has them clean it out it would pay for itself in gas savings? Car runs fine. He said carbon builds up inside and causes problems. Should I leave it alone do you think?
Old 03-20-2008, 12:13 PM
moe's Avatar
moe
moe is offline
hi lerry,some cars do get a build up.just take a small rag spray with carb cleaner.and open blades and wipe clean.ive seen when the little red straw blows inside the intake.ps make sure the car is not running!") moe
Old 03-21-2008, 02:23 AM
lerry1957's Avatar
Hey Moe thanks for the reply. There is no little bleed/vent hole near throttle blade to worry about?
Old 03-21-2008, 09:36 AM
moe's Avatar
moe
moe is offline
there is a hole for the iac motor but you be ok with a clean rag.moe
SpudlerT+CTouring
02-02-2012 01:05 AM
15951a\
12-18-2011 08:22 PM
Discovering06
07-07-2011 09:10 AM
xianh
01-25-2010 06:52 AM
3.3lxbluevan
12-09-2008 08:55 PM
Quick Reply: Throttle body cleaning?
