1994 LHS Transmission Seal
Old Jun 13, 2024 | 10:53 AM
SpeedBanana's Avatar
Default 1994 LHS Transmission Seal
My 1994 LHS went into the transmission shop because antifreeze leaked into the trans oil cooler. The trans was rebuilt and worked fine for a brief time but then the front seal on the trans blew out. They fixed the seal and the second seal also blew out. Does anyone have a trick or tip to help them get it right on the third try? Thanks in advance.
Old Jun 13, 2024 | 11:31 AM
FIREM's Avatar
Many potential causes that I would guess a trans shop would investigate. A few that come to mind…..
Vents and Vent Tubes
Engine crank shaft endplay.
Proper Torque Converter seating & End play
Seal surfaces both bore and shaft.
Old Jun 13, 2024 | 12:12 PM
ggoose's Avatar
Suggest using an OEM/Mopar seal. Had a '97 intrepid with the 3.5l. Cam seal started leaking. Shop replaced with aftermarket which immediately pushed out. After 2 attempts with aftermarket, used OEM/Mopar and seal stayed in place.
97_chrysler_lhs
9
Mar 26, 2013 06:12 PM
Cliff250
Nov 21, 2011 10:50 PM
john franklin
Aug 2, 2011 05:58 AM
Stevesalerno
Jan 19, 2011 09:56 AM
milesy_boy
11
Nov 19, 2009 05:34 PM
