1999 LHS LO beam lights
Old Apr 5, 2011 | 08:19 PM
RESORT2ME's Avatar
Question 1999 LHS LO beam lights
Flashing off and off - lo beams only
Anyone with a fix for this situation?
Old Apr 5, 2011 | 08:33 PM
Djinn-n-Tonic's Avatar
Turn the key in the passenger door.
When did this start?? Is the car equipped with factory Security??
Old Apr 5, 2011 | 10:31 PM
RESORT2ME's Avatar
Two weeks or so ago. And yes it has factory security.
Grand daughter was driving it. She called me saying the lights were going off and on. I recommended using brights.
I could not duplcate. Later, she said same occured. I also found the 'remote key' was inoperative. I unlocked passenger door with key to check for something in glove box. I replaced the battery in remote. It now works fine. My grandson took the LHS to Nashville. Has said nothing about the lights.
What's with the passenger door lock affecting the LO beam headlights??
Old Apr 5, 2011 | 11:28 PM
The lights flash when the alarm is triggered.... The "Disarm" switches are built into the lock cylinders in the door handles
The drivers door will work as well, to disarm the system, but I figured that was TOO obvious and you would have tried already.
Old Apr 7, 2011 | 05:59 AM
RESORT2ME's Avatar
The car had been operating for two miles prior to the flashing, She cell-phoned about the dims flashing, I told her to run with brights (as I knew the lens were cloudy) and that satisfied her.
Your info makes good sense. Does the alarm flash the dims only?
Once the car returns from Nashville, I'll become better aquainted with the alarm system
Old Apr 8, 2011 | 07:09 PM
anwaypasible's Avatar
maybe somebody is twisting the headlight switch, and the new position that they put it in has a short.
leaving it on automatic (if there is a short/dirt) can cause the lights to turn on and off.
twisting the **** to 'manual' (if there is a short) can also cause the lights to turn on and off.
also,
adjusting the interior brightness ****.. if the **** is just before the 'click' that switches the parking indicator and odometer lights from day mode to night mode.. that can cause the parking indicator and odometer lights to flicker.
it does that on mine, and i just turn the **** down a little bit more and it stops.
i think the other poster was trying to say, using the other door lock would turn off the alarm system IF the driver's door lock wasnt disabling the alarm.
since you have tried both doors, i would think its the switch.
i dont know how the factory alarm works, but maybe the alarm prevents the car from starting?
the lights should blink and the horn should beep if the alarm goes of.. and thats at the very least.
Old Apr 9, 2011 | 09:59 PM
RESORT2ME's Avatar
Thumbs up Thanks
It has never done it for me and no horn beeped for her. I'll be greatful if I never find out what was going on, but I agree that it was security system related. Thanks for the responces.
Old Apr 10, 2011 | 01:10 AM
i thought, maybe your daughter is adjusting the **** and putting it back to the original position.. which is why you never seen it happen.
polite of her.. but sticky-icky when trying to find the source.
the horn works when you push on the button of the steering wheel?
i dont think the headlights have but two methods to turn on.
one is the headlight switch itself.
the other is the alarm system.
if the switch is good, then the alarm computer is going stupid.
i've never ever heard of the alarm computer malfunctioning.
have heard of the headlight switch giving problems for many people.
if you havent already.. try adjusting the headlight switch to something different than the usual setting.
lmekic06
Nov 13, 2011 03:52 PM
ajs42548
Jan 19, 2011 01:45 PM
wig6516
Mar 15, 2008 10:14 PM
wig6516
Dec 18, 2007 02:38 PM
kmatwill
9
Apr 1, 2007 03:52 PM
