2002 300M dies then starts.
Old Dec 11, 2012 | 08:00 AM
nates90's Avatar
Default 2002 300M dies then starts.
I'm trying to figure out was is wrong with my 300M. It started doing this when it got cold out (around 5-20 F). I started it in the morning fine and went down the road about 3 miles and started to stop for a stop sign and it just died. I turned it over and it started right up with my foot on my pedal a little. I had to drive it the rest of the way to work double footed to keep it running. Sometimes after running it for awhile and shut it down. Then come back about 5-10 min, it will not start unless I have my foot on the throttle a little. Also wanted to add I think the fuel pump has been sounding fishy lately. Thanks.
Old Dec 11, 2012 | 12:34 PM
what are the codes in the computer?
Old Dec 11, 2012 | 02:39 PM
nates90's Avatar
I have not checked the computer codes, but I do know the check engine light didn't come on.
Old Dec 11, 2012 | 05:12 PM
Familyman2000's Avatar
Try cleaning the throttle body. I think that is a pain on this model, but definitely a DIY project. Carburetor cleaner and a toothbrush, and maybe a mirror. Consider, but probably not necessary, removing the Idle Air Control motor, so you can clean even better.
IAC motor could be bad, but not a common problem. Make sure your Check Engine lamp is not burned out- it should come on for a few seconds when turning the key "on", engine off.
Old Dec 11, 2012 | 10:41 PM
turn the key on position where all the lights light up then back off repeat 3x 3rd time leave key one and poXXX codes will be displayed where the miles are.
Old Dec 12, 2012 | 07:17 AM
nates90's Avatar
Just wanted to update you guys. I put a new fuel pump in the car, it runs like it is brand new now. I then changed the spark plugs and oil. Should be good to go for awhile. I think I will check the codes next time I get in though. Thanks for the responses.
Nudge
Apr 19, 2015 02:52 PM
aaron1wii
Aug 26, 2014 01:05 PM
RogueInLA
Mar 31, 2014 08:54 AM
Titusflumpo
Jun 21, 2011 04:09 PM
TCIDAD
Nov 12, 2008 11:52 AM
