2.8CRD starts then stalls from cold!!!
Old Jun 18, 2011 | 02:55 AM
Titusflumpo's Avatar
Default 2.8CRD starts then stalls from cold!!!
Hi Guys,
As the title says, my 2.8 CRD will start from cold but then stalls after about 30 seconds. Then it is a real struggle to get it started again. When it does get going, everything seems perfectly normal.
Any suggestions will be much appreciated
Old Jun 18, 2011 | 10:41 AM
booke23's Avatar
What age is it? and what mileage?
Old Jun 18, 2011 | 04:02 PM
Thank you for your reply.
It's a 2007 model registered in 2008 with 100,000 miles on her.
She's been serviced on the button and just had timing belt changed last week.
Regards
Old Jun 20, 2011 | 05:37 PM
Any suggestions, anyone, please
Old Jun 21, 2011 | 04:09 PM
booke23's Avatar
Are you saying that you can start it from cold, but it never runs more than 30 seconds? And it will restart after you turn the ignition off for a while?
If so then it sounds a bit like a failed crank shaft position sensor. There should be a fault code if that is the case.
Nudge
Apr 19, 2015 02:52 PM
aaron1wii
Aug 26, 2014 01:05 PM
nikon70
Mar 1, 2013 03:31 AM
nates90
Dec 12, 2012 07:17 AM
TCIDAD
Nov 12, 2008 11:52 AM
