94 Concorde a/c blowing extremely hot air
I've had this one... trying to remember... with the digital heat control - 99 concorde
On the hottest day of the year, the heater was running on HOT/DEF/MEDIUM speed, which I know is the failsafe mode. I took out a fuse (I think the a/c?) and it went to HOT/DEF/HI. The digital heater panel reads " -- " and will turn itself back ON when you turn it OFF.
I thought it might be the digital heater control, so I swapped it (always have a spare for these...) - NO CHANGE! So it wasn't the control.
I believe I pulled fuses one by one, and one of them 'fixed' the problem. I think it was the 'raised' fuse which also controls the engine/security etc (I think)
I'm not sure why it happened. My 1999 Concorde seems to kill the battery (parked) MUCH faster than any car I've ever had. Electronics do not like undervoltage and can do weird things when it happens - and it happens more than average in a Concorde... Security system also does not like low voltages...
Clausen Headed for Visit with Bills,John Elway jerseyBUFFALO (wgrz) - Notre Dame quarterback Jimmy Clausen says he's headed for his scheduled pre-draft visit with the Buffalo Bills as soon as doctors check on his surgically reparied toe.,Austin Collie jersey, the family dwelled in daleville,Troy Aikman jersey, alabama, where tony excelled as a three-sport letterman in football, basketball,Chad JOHNSON jersey, and pathway & field.Clausen worked out for NFL scouts Friday in South Bend.martin tevaseu height:6-2 weight:325 age:22 college:nevada-las vegas experience:r team:new york jets martin tevaseu (dt/6-1/310/nevada-las vegas/boonville,Marion Barber jersey, ca) was before marked as an undrafted free agency by the cleveland browns on may 17,JASON WITTEN Cowboys Jersey, 2010,Brian Cushing jersey, and was issued on june 15.? He was speaking with ESPN following the workout and said that the next team he plans to visit is the Buffalo Bills. he subsequent tweeted it was time to wake n bake," a quotation to marijuana. That's a visit that's been scheduled for several weeks.' he has abounding of arm. The Bills also hosted Florida quarterback Tim Tebow early last week. bo bo smith what they're saying: showing a lot of natural skill and giving effort on the field,JEFF SATURDAY jersey,bo smith is an aggressive cornerback with good upside.Clausen says he'll head to Indianapolis on Saturday where doctors want to check on the progress of his surgically repaired toe.) with 2 tds in 2002 regardless of missing 5 sport with a knee injury. Clausen told ESPN he plans to fly to Buffalo after that.) with 23 tds while catching 13 passes for 200 backyards (15.The Bills pick 9th in the first round of the NFL draft and with the Redskins trading for Donovan McNabb,B.J. Raji jersey, there's growing speculation Clausen could be available when the Bills select.(* comprises nfl combine) carolina panthers kris jenkins completed the 2002 time of the year with 60 undertakes and 7 dismisses,Roddy White jersey, en path to an alternate look on the nfc's pro bowl group,BOB SANDERS jersey, where he restored an hurt warren sapp.??-abenigni@wgrz.,JIM PLUNKETT jersey, has been chosen to five pro bowls and has been an all-pro six times.gannett?Topics related to the article: Willis Mcgahee Jersey Change would ease access to CORTLAND FINNEGAN jersey Bayless -exposed- in publ Adrian Peterson Vikings Jersey Giants, Dolphins, F
Short history... 2009 T&C 3.8: A/C blows cold, no problem. Intermittently, it would blow HOT. I'm not talking "not cold", I mean full on hot air. After finding this forum, my blender door was broken, replaced it, and wahlah, right? NOT! It did it again 2X. Head scratching, what's up? Looking at eManuals' pictures and diagrams, I notice there is a temperature sensor on the evaporator in the lower corner. When I replaced the blend door, I noticed a few pine needles in the fan. Curious? Looked up and forward through the blend door housing and saw a few more that had been caught by the mesh. Because of the angle, I didn't realize how many. I removed the windshield wipers and cowl. On passenger side, from the left looking at the engine, there is a square hole, then four rectangular holes. I shoved a small vacuum hose into the first rectangular hole aiming back towards the square hole (towards the passenger door), and heard many leaves, and maybe a few acorns being removed. No problems since. The science behind, and why? The A/C system is designed to keep temps somewhere between 60 to 85 degrees F. If your A/C is chilling right along and the airflow is obstructed over that before mentioned evap temp sensor, it is no longer having the ambient air to warm the sensor. It will get super cold. Much colder than the lowest (60-ish), setting the system is designed to maintain. So, what does it do? It adds hot air as long as that evap temp sensor is covered, trying to get the temperature back into the 60 to 85 deg range. If the leaf drops away, your A/C goes back to normal. Leaf flips up in front of sensor, it blows hot again. Doesn't cost anything and can be done in an hour or two. I hope this helps. Be cool (as you want to be).
whip007
Oct 29, 2013 10:04 AM
studentmechanic
Oct 30, 2007 10:53 PM
