99 2.7 Timing Chain Tensioner problem!
Old May 4, 2008 | 07:46 PM
bacalao's Avatar
Default 99 2.7 Timing Chain Tensioner problem!
Hello everyone my first post here hopefully you can help me with my 99 Concorde 2.7 107000k
I recently replaced the power steer assist and it all went well but the car sat there for over a month on an incline before I fixed it and I started it without priming the engine now I have this knock sound and does not go away so, I Take the valve covers off everything looks okay then I take the bottom off and check the connecting rod bearing they also look good, so nooooowww I take the frontend and timing cover off and I turned the engine with a big ratchet I noticed that the timing chain tensioner was priming it self and snapping back with each revolution, before I keep going and take the timing chain and sprocket from the main off to check the oil pump does anyone have any suggestions’
jimG
Aug 24, 2016 10:34 PM
jimG
Aug 24, 2016 10:24 PM
lovenhate300m
12
Mar 29, 2012 11:50 PM
bacalao
May 9, 2008 11:34 AM
bacalao
May 4, 2008 04:15 PM
