Fan A/C problem
Old Oct 13, 2008 | 10:26 PM
mstjohn1974's Avatar
Default Fan A/C problem
Hello,
I am having a problem with my '98 Chrysler Concorde LXI. The Fan/AC wont turn off. Its getting worse ..if I turn off the AC the fan starts running very very fast...and I cant turn it down...any ideas what that could be...Is the speed turn **** malifunction?
I appreciate every post...thanks
Old Oct 14, 2008 | 09:36 AM
Iwant2playNOW's Avatar
Default RE: Fan A/C problem
I had a similar problem last year...it ended up being a bad battery.
Old Oct 14, 2008 | 11:39 PM
blower motor resistor power module
Old Oct 30, 2008 | 02:10 PM
manshack_one's Avatar
I'm having a similar problem. 98 Concorde LXI with ATC. Auto works fine when used. The system regulates itself and fan speed is variable. When I turn the **** it switches to manual on the head unit display and the dash fan turns off but the defrost blower kicks in and the speed goes to kind of a medium speed. The air is just outside air. Doesn't matter where I turn the fan speed **** to it results the same each time. It won't shut off either. I press off and the display goes away but the fans start blowing from the back like when it goes to manual. I pulled the fuses for it the other day just to get a break from the noise of it and it's still doing it. Ran the diagnostics by holding the three buttons down but didn't get an error code.
Old Nov 4, 2008 | 04:28 PM
I got some error codes last time I checked my ATC diagnostics. 36 and 26. I'm guessing the head unit is on the way out.
Master Chief
Jul 17, 2009 03:00 AM
colbertgang
Apr 26, 2009 09:30 PM
300winchester
Mar 29, 2009 02:48 PM
russ1960
Oct 21, 2007 08:46 PM
NYcruiser
Jan 30, 2007 05:51 PM
