3.3 Voyager – Fan Problem
Old Jul 17, 2009 | 03:00 AM
Master Chief's Avatar
Default 3.3 Voyager – Fan Problem
Hi,
I have a small problem with my engine cooling after the AC compressor and/or AC Clutch gave in (no idea which one was first) earlier today – just two days for our vacation. Great timing of course. No time to wait for the new parts...
I first removed the AC compressor and that was... well dead beyond repair. I had to remove everything inside the compressor, to let it spin, and removed the plug to the AC Clutch (also broken) to make sure it won't engage when the AC buttons is pressed by one of the children, or me.
So the work around for the AC problem is in place – I will have to fix this AC problem after our vacation – but now the fans don't kick in as usual and thus the engine runs a little hotter (please note that we drive on LPG here, because that is more environmentally friendly, but the engine runs a lot hotter than your usual fuel).
I might have to insert a jumper wire into the pressure sensor, to fool the PCM since the AC is dead and thus that won't trigger the fans anymore. Or I might (temporarily) use the AC button, to manually start the fans when needed. Never done anything like this before... but for everything a first time they say.
Note: The wiring, fuses and fans, including the fan relay and temp sensor are all fine (just for the record).
Tips are welcome!
colbertgang
Apr 26, 2009 09:30 PM
300winchester
Mar 29, 2009 02:48 PM
mstjohn1974
Nov 4, 2008 04:28 PM
russ1960
Oct 21, 2007 08:46 PM
NYcruiser
Jan 30, 2007 05:51 PM
