Head Gasket replacement
Old Aug 11, 2012 | 08:50 PM
Jbray59's Avatar
Default Head Gasket replacement
This is similar to another post about coolant disappearing. I need to know how much is involved in replacing a head gasket on a 2000 Chrysler LHS. I have replaced all the hoses, water pump but not the radiator and completely flushed the system. I did a pressure test and there are no leaks anywhere. I took it to the shop and was told I have a leaking head gasket since it has a rough idle when cold and there are no leaks visible. It takes about 400 miles or so and then I notice that I need to add more coolant.
Is this a job that is better left to a mechanic? Thanks!
Old Aug 12, 2012 | 12:46 AM
buy a service manual read what it takes to do the heads then u have an educated decision u can make
Old Aug 12, 2012 | 04:26 PM
Jbray59's Avatar
Already have a haynes manual. I should have added or asked if that is possibly a description of a leaking head gasket.
Old Aug 12, 2012 | 05:38 PM
the 3.5 have been know to push out the coolant when the heads are real hot the heads will need to be replaced or machined back to spec
04pacifica
Sep 3, 2012 06:02 PM
madmantrapper
Oct 6, 2010 07:59 PM
davidandkeiley
Sep 2, 2007 10:28 AM
lutzsucceed
Aug 16, 2007 03:58 PM
bakerman
Jul 24, 2007 05:24 PM
